1988 Ford Bronco ignition
DON KUMAR
  • 1988 FORD BRONCO
  • V8
  • 4WD
  • 17,000 MILES
I was at the store. I went to shut off the bronco and the key turned back but the engine kept running. I got home and had to pull the coil wire to shut it down. But I had to pull the battery cable to kill the power. It doesnt matter where the key is, the power remains on. I can turn the ignition with or without the key. But I cant get it to start? The key will lock the steering. But the power stays on no matter what. Thanks Don
Do you
have the same problem?
Wednesday, September 2nd, 2009 AT 1:08 PM
Replace the ignition switch
Wednesday, September 2nd, 2009 AT 2:59 PM
Recommended Guides
