1988 Ford Bronco Bronco II intermittent ignition
KB7WG
  • 1988 FORD BRONCO
  • 6 CYL
  • 4WD
  • MANUAL
  • 300,000 MILES
I have replaced plugs, wires, cap and rotor, module on distributor, coil and capacitor on coil with no improvement.
when I start the truck. It starts easily with key in the start position. As soon as I let the key go to the run position it quits.
once in a while the truck starts like new and runs for about 15 min. Then back to where it will start. But not run.
i thought about the resistor(22K OHM) in the run circuit, but discounted that because the truck does run once in a while.
any help would be appreciated.
thank you.
earl
Do you
have the same problem?
Monday, April 5th, 2010 AT 12:16 AM
  • EXPERT
Have you checked the ignition switch itself?
Tuesday, April 20th, 2010 AT 11:35 AM
Recommended Guides
