1988 Ford Bronco
AMBREES1
  • 1988 FORD BRONCO
  • V8
  • 4WD
  • MANUAL
  • 63,981 MILES
I just bought a 1988 Ford Bronco that was setting for two years. I drained out all the old gas and cleaned out the fuel filter an fuel pump. I put ten
gallans of high test gas in the tank. The engine starts
and idles fine but will not rev up when I step on the gas. I checked the fuel rail pressure and have 32 psi.
I also installed a new battery.
Do you
have the same problem?
Saturday, August 8th, 2009 AT 12:32 AM
Check and test the TPS and MAP sensors
Saturday, August 8th, 2009 AT 1:48 AM
Recommended Guides
