1987 Ford Bronco will not start or go into gear
BRONCO BILLY
  • 1987 FORD BRONCO
  • V8
  • 4WD
  • 150,000 MILES
I got it started by jumping the posts on the starter cylenoid, so I replaced starter cylenoid and it still would not start. I noticed the key feeling a little weird ( does not spring back from start postion)when you tried to start it and also the fact that you could no longer put it in gear and that the electronics were being weird (staying on in lock position, not coming on in pre-start position etc.) I replaced the key lock cylinder, still no luck. Could this possibly be the ignition switch? Or any other ideas would be greatly appreciated. Thanks
Do you
have the same problem?
Friday, March 19th, 2010 AT 2:43 PM
DOCFIXIT
  • EXPERT
Go with the ignition switch
Friday, March 19th, 2010 AT 2:49 PM
Recommended Guides
