1987 Ford Bronco high idle
MULISHAMIKE21
  • 1987 FORD BRONCO
Engine Performance problem
1987 Ford Bronco V8 Four Wheel Drive Automatic 150k miles
I have replaced the idle control valve, throttle position sensor, and the throttle body gasket on my 87' bronco and it still idles too high. It is idling arond 2000rpm when in park or neutral. The motor runs fine other than tha. What could I be looking at?
Do you
have the same problem?
Sunday, October 12th, 2008 AT 9:24 PM
RENAUDTN
Check for vacuum leaks
Monday, October 20th, 2008 AT 10:33 AM
Recommended Guides
