1987 Bronco II won't start
CWEATHERLY
  • 1987 FORD BRONCO
Replace fuel pump in tank and all kinds of relays. Any ideas?
Do you
have the same problem?
Thursday, July 26th, 2007 AT 12:58 PM
KKIDD4
Have u checked the fuel pump thats on the rail under the drivers door? Are they both getting power? We had the same problem replaced the pumps and the tanks and the relay finally found a broken wire in the fuselink for the pump hope this helps
Monday, July 30th, 2007 AT 6:10 PM
Recommended Guides
