1994 Ford Aerostar No Fire on spark plugs
GIAAHVAC
  • 1994 FORD AEROSTAR
Electrical problem
1994 Ford Aerostar 6 cyl Two Wheel Drive Automatic
Van suddenly died on road. Did a tune up- cap, rotor, wires, and spark plugs. Still did not have fire. Then went further and found the ignition module burned. Replaced that as well. Still no fire.? The module had to be replaced by pulling the distributor shaft out and placed back in. We also had a different computer box installed to cover all areas. Then we changed the ignition coil. Still No FIRE. Now we are really out of answers. The Distributor does turn when cranked over. No spark.?
Do you
have the same problem?
Friday, July 3rd, 2009 AT 1:40 AM
  • EXPERT
Are you getting power to the coil?
Friday, September 11th, 2009 AT 8:19 AM
Recommended Guides
