1994 Ford Aerostar LEAK
RAYSPLAYS
  • 1994 FORD AEROSTAR
  • 6 CYL
  • 230,500 MILES
Under the master cylinder there is another unit with break lines connected to it. It's approximately 1" thick, 5" long and 2" high. I think it has something to do with the ABS system. On each end there is a hex fitting that looks like a plug. The one on the left as you stand in front leaks a little. Is this fixable?
Do you
have the same problem?
Monday, April 19th, 2010 AT 10:12 PM
  • EXPERT
Is there a hose going into it or only a plug?
Tuesday, April 20th, 2010 AT 8:21 AM
Recommended Guides
