1992 Ford Aerostar Heating / electrical
WHITEWINGSWOLF
  • 1992 FORD AEROSTAR
1992 Ford Aerostar 6 cyl Two Wheel Drive Automatic
my van will run for miles then stop. We have to wait for it to cool before we can run it again. There is no steam. The distributor cap is warm but not hot. The engin itself is not overheated. We got it diagnosed, the KOEO said 172 212 116 167. We changed the O2 sensor and she still does it. When it's cool outside she can run for miles. When she stops the check engin lite goes on then acts as if shes not getting gas. We dont understand how to fix 212 as we dont have a repaire manual. The coolant temp is too low cause we tried to take out the temp regulator to see if that worked. Before we did that the fulid wasn't going through at all. She runs longer now, but still stops. The fan is running well as well.
Do you
have the same problem?
Tuesday, July 20th, 2010 AT 12:07 PM
  • EXPERT
Have you checked fuel pump pressure?
Friday, August 13th, 2010 AT 10:22 PM
Recommended Guides
