Flywheel problem
BIGTREECHUCK
  • 2004 HONDA ACCORD
  • 1.4L
  • 4 CYL
  • 92,000 MILES
The starter occasionally won't engage due to the flywheel teeth having slight burrs. Can I file the burrs off instead of replacing the flywheel? Can the engine be rotated for this procedure?
Do you
have the same problem?
Monday, January 4th, 2016 AT 11:55 AM
HMAC300
  • EXPERT
No the teeth are probably worn out
Monday, January 4th, 2016 AT 12:10 PM
Recommended Guides
