HOME
ASK A QUESTION
REPAIR GUIDES
BECOME A MEMBER
LOG IN
Login with Facebook
OR
Remember me
NOT A MEMBER?
FORGOT PASSWORD?
CONTACT US
PRIVACY POLICY
TERMS AND CONDITIONS
Home
Buick
Regal
Ignition
Firing Order
SPONSORED LINKS
Firing order
DADDYRABBIT57
MEMBER
1998 BUICK REGAL
6 CYL
FWD
AUTOMATIC
15,000 MILES
What is the proper firing order for the 3.8 liter v6
Thursday, April 30th, 2009 AT 10:34 PM
MECHANIC
SPONSORED LINKS
Thursday, April 30th, 2009 AT 11:44 PM
MASTERSHAKE503
MEMBER
1 POST
1992 BUICK REGAL
Engine Mechanical problem
1992 Buick Regal 6 cyl Front Wheel Drive Automatic
i need to know the firing order plane and simple I cant find it anywhere on the net thank you
Thursday, May 23rd, 2019 AT 3:05 PM (Merged)
ZACKMAN
MECHANIC
3.1L
3.8L
BDBUICK
MEMBER
1 POST
1986 BUICK REGAL
V8
2WD
AUTOMATIC
88,250 MILES
What is the firing order and wire to cap placement is it the same as all gm hei
SERVICE WRITER
MECHANIC
SPONSORED LINKS
Thursday, May 23rd, 2019 AT 3:06 PM (Merged)
BRUCE CANNON
MEMBER
1 POST
1989 BUICK REGAL
3.1L
6 CYL
2WD
AUTOMATIC
150,000 MILES
I need the firing order, three coils up front.
Monday, September 7th, 2020 AT 11:41 AM (Merged)
MECHANIC
Here is the engine firing order. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Image (Click to make bigger)
Please
login
or
register
to post a reply.
Related Firing Order Content
1998 Buick Regal Interment Noise, Fan Blowing All The...
The Fan Would Make A Loud Creaching Sound Occasionally. Today I Turned The Fan To Number 2 And It Began To Blow Full Force And Would Not...
Asked by
ruthie blue
1 ANSWER
1998
BUICK REGAL
Coil Pack Has No Spark For Cylinders One And Four
Coil Pack For #1 And # 4 Has No Spark. Replaced It, Still No Spark To Plugs. Tested Prongs At Mount Tabs And Found 12 Volts On One, None...
Asked by
stw
1988
BUICK REGAL
1988 Buick Regal No Spark
Electrical Problem 1988 Buick Regal 6 Cyl Front Wheel Drive Automatic 200k Miles I've Had The Coil Packs And Ignition Module Checked...
Asked by
Thumpnit
1988
BUICK REGAL
How To Roll The Engine Forward To Get At The Rear...
I Just Want To Ensure That I Know The Procedure. Do I Have To Disconnect The Throttle Cable?
Asked by
Bill Doubleu
1 ANSWER
1995
BUICK REGAL
The Car Has A 3.1 Lt Engine Which Will Not Start...
The Car Has A 3.1 Lt Engine Which Will Not Start, Starter Turns Engine Over, Battery Volts 12.5, Ignition Module Has Been Replaced And Is...
Asked by
WWHEELS
1 IMAGE
1991
BUICK REGAL
VIEW MORE
SPONSORED LINKS
Spark Plug Replacement Ford Explorer 4.6L V8
How to Repair an Engine Cylinder Misfire
Spark Plug Toyota Tundra V8 4.7L 2000-2006
Online car repair manuals
