2000 Fiat Punto gasoline into oil
JORFE
  • 2000 FIAT PUNTO
Engine Mechanical problem
2000 Fiat Punto 4 cyl Two Wheel Drive Manual
Good afternoon
I have a fiat punto and it passes gasoline into the oil gasket, I know that it didn’t pass by the injectors because they were under pressure 48h and they didn’t leak any gasoline.
What I want to know is were is possible to pass gasoline into the oil.
Thanks
Jorge
Do you
have the same problem?
Tuesday, July 7th, 2009 AT 1:08 PM
DAVE H
  • EXPERT
Check for combustion in every chamber
Sunday, November 8th, 2009 AT 6:19 AM
Recommended Guides
