Exterior lights/ dashboard lights/ interior lights
MKS64
  • 2001 DODGE DURANGO
  • 17,800 MILES
Have no headlights or parking lights also dashboard lights not working. Checked the relay which is good, checked all fuses for power, multifunction switch good. Was thinking headlight swtich but theirs no power to the plug, is their suppose to be continuous power to the plug? Brake, reverse and turn signals working.
Do you
have the same problem?
Sunday, July 14th, 2013 AT 9:13 AM
HMAC300
  • EXPERT
Check ground behind right kick panel but this may be the central timer module as they have had several mods to it.
Sunday, July 14th, 2013 AT 10:06 AM
Recommended Guides
