Ex messed up transmission I think
MELISSA 1981
  • 2008 CHEVROLET SILVERADO
  • 4.8L
  • V8
  • 4WD
My ex is a mechanic and a felon. I had to get the cops to get my truck back. Now I'm pretty sure it's the transmission. The throttle is erratic. There is enough fluid what's you're guess on what he did?
Do you
have the same problem?
Wednesday, November 11th, 2015 AT 11:14 PM
CARADIODOC
  • EXPERT
Really? I don't use a dart board to make a diagnosis. You didn't provide one useful detail, clue, observation, or a hint of a symptom. By "erratic throttle", are you referring to an unstable idle speed? The engine speed doesn't respond as expected when you press the accelerator pedal? You have to provide some details, but it's not likely I can tell what or if someone did anything on purpose to cause a problem.
Wednesday, November 11th, 2015 AT 11:51 PM
Recommended Guides
