EPC lights up when Engine is started
KOTU CHAM
  • 1997 MERCEDES BENZ C220
  • 281,000 MILES
Sometimes when I switch on the ignition all the lights on the dash board come on and when the engine starts all go off except the EPC. At this point the engine does not run smoothly, and any attempt to push the accelerator pedal, the engine wants to stall. When I switch off the engine and restart the engine the EPC light goes off, and the engine runs smoothly and the accelerator pedal is fine. This problem does not happen always, though.
Do you
have the same problem?
Tuesday, May 14th, 2013 AT 6:10 AM
SEANGRANT00
  • EXPERT
There is not a model C220, is it a c230?
Monday, July 8th, 2013 AT 6:41 PM
Recommended Guides
