High pitched engine squeak
GARYA1983
  • 2006 VAUXHALL ASTRA
  • 1.3L
  • 4 CYL
  • MANUAL
  • 120,000 MILES
So I have a high pitched squeak coming from the engine block. I have removed the aux belt to see if it was the water pump or A/C pulley, but the squeak continues. The car has a drive chain which should not squeak. Does anyone know what it could be if it's not the chain? Or come across this problem before.
Do you
have the same problem?
Wednesday, August 14th, 2019 AT 8:58 AM
KASEKENNY1
  • EXPERT
Is it possible for you to get a recording of this noise and post it here so we can listen to it and try to identify what it is?
Thanks
Wednesday, August 14th, 2019 AT 4:11 PM
