Engine running
AUTO4ART
  • 1999 CHEVROLET ASTRO
Only starts for startspray, when ilding and throttle is at 1/4 peddle rpms rise, but when the peddle past 1/4 throttle rmps fall and motor wants to shut down, if peddle is released quickly, motor will continue to idle
Do you
have the same problem?
Wednesday, May 29th, 2013 AT 8:59 PM
HMAC300
  • EXPERT
Check your fuel pressure first should be 60-66 psi
Thursday, May 30th, 2013 AT 6:56 AM
Recommended Guides
