Engine replacement
CHAD88FAN
  • 2008 SATURN VUE
  • 2.4L
  • 4 CYL
  • FWD
  • 177,000 MILES
I need a estimate on how much it will cost to have a reconditioned engine put in my 2008 saturn vue
Tuesday, April 14th, 2015 AT 12:42 PM
RIVERMIKERAT
  • 6,110 POSTS
Labor usually runs anywhere from about $600 to $800 the engine should run about $1500.
Tuesday, April 14th, 2015 AT 1:37 PM
CHAD88FAN
You are spot on cost me $2300.00 Thank you for all your help!
Tuesday, April 14th, 2015 AT 4:21 PM
RIVERMIKERAT
  • 6,110 POSTS
Nice work, we are here to help, please use 2CarPros anytime.
Cheers
Wednesday, April 15th, 2015 AT 6:28 AM
TOMMY QUINTANILLA
  • 2007 SATURN VUE
  • 2.2L
  • 4 CYL
  • FWD
  • MANUAL
  • 186,347 MILES
I need to replace the engine.
Thursday, October 4th, 2018 AT 11:00 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
Here is how you replace the engine in your vue the V6 is very similar. Check out the diagrams (BELOW)
Engine Replacement
Tools Required
J 36346 Fascia Retainer Remover
J 39914 Serpentine Belt Tension Unloader
J 43828 Ball Joint Separator
J 44811 Accessory Belt Tensioner Unloader
J 45341 Rear Wheel Drive Shaft Removal Tool
SA91100C Tie Rod Separator
SA9127E Gage Bar Set
SA9805E Fuel Line Separator
Removal Procedure
Disconnect the negative battery cable.
Disconnect the air intake temperature (IAT) sensor connector.
Loosen the clamp air cleaner assembly.
Drain coolant.
Evacuate the air conditioner
https://www.2carpros.com/articles/re-charge-an-air-conditioner-system
Engine Assembly - PN 12609605 $3500.11
14.3 hours @ 85.00 = $1251.00
Cheers
LANAJJ
  • 5 POSTS
  • 2003 SATURN VUE
  • 6 CYL
  • AWD
I need to replace the engine in my car. How much should a 2003 Saturn Vue 6 cy AWD engine cost?
SATURNTECH9
  • 30,870 POSTS
SO are you looking to put a new engine in or a used one?
LANAJJ
  • 5 POSTS
A new one
SATURNTECH9
  • 30,870 POSTS
The engine list price is 8,755.00 plus tax. The labor is
Complete Assembly With Transfer Of Parts B 0.0 10.8hrs labor
Includes: Transfer All Fuel & Electrical Units. Does Not Include: Transfer Of Optional Equipment.
Long Block B 0.0 15.3hrs labor
Includes: R&I Engine And Transfer All Necessary Components Not Supplied With Long Block.
The labor hrs is time's shop labor rate 80-100 per hr?Plus you will need a alignment when it's replaced.
ROCHELLEFOWLKES
  • 6 POSTS
  • 2003 SATURN VUE
  • 6 CYL
  • AWD
  • 76,000 MILES
I was told that my engine had to be replaced, how much does this cost, and how long does it take to repair?
BLUELIGHTNIN6
  • 16,542 POSTS
Takes around 7.5 labor hours to remove and replace your vehicle's engine assembly. That is approx. $500 labor fees in most shops.
TWOEDGE ELFFIGHTER
Need to replace engine in my 2003 Saturn Vue awd (3.0 engine).
Thursday, January 7th, 2021 AT 1:48 AM
TWOEDGE ELFFIGHTER
Used is fine.
Thursday, January 7th, 2021 AT 1:59 AM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
What kind of help do you need?
Saturday, January 9th, 2021 AT 5:55 PM
