Engine Keeps Running Even When Ignition Is In OFF Position
IMRAN_SQUAREPANTS
  • 2002 SUBARU LEGACY
  • 2.0L
  • 4 CYL
  • TURBO
  • AWD
  • 186 MILES
Drove to work today and as soon as I was parked I turned off the ignition but the engine was still running. The dash stayed on. The AC and the audio system turned though. I unplugged a battery terminal to kill the engine. I tried to start it again and it started fine but still wouldn't go off. I ended up unplugging the ignition fuse to kill it. What could be causing this problem? Thanks.
Do you
have the same problem?
Wednesday, July 8th, 2015 AT 10:40 AM
KHLOW2008
  • EXPERT
Check the ignition switch and main relays.
Wednesday, July 8th, 2015 AT 11:51 AM
Recommended Guides
