Engine timing belt
QUINTON GOOLSBEY
  • 1987 CHEVROLET CELEBRITY
  • 160,000 MILES
My car is not starting and I think it may be my timing belt. I want to know how to fix my timing belt if it is off?
Do you
have the same problem?
Saturday, February 18th, 2017 AT 8:39 AM
JDL
  • EXPERT
You do not have a belt, it should be a timing chain. I do not know liter size of engine? What makes you think it is a timing chain? What kind of testing have you done? Engine cranking, do you have spark at the plugs? Do you have good fuel pressure? Is there a fuel injector pulse? Any applicable trouble codes? Can you check cylinder compression? You need to decide first if it is the chain, go from there.
Saturday, February 18th, 2017 AT 10:45 AM
Recommended Guides
