Removing and replacing alternator?
CHARLES MCGHEE
  • 1999 HONDA ACCORD
  • 4 CYL
How to remove the alternator on 1999 honda accord
Tuesday, August 9th, 2011 AT 6:22 PM
Here is a guide to help you step by step with instructions in the diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-alternator
ALTERNATOR
Removal (2.3L)
Ensure you have the anti-theft code for the radio. Write down the frequencies for the radio's preset buttons.
Disconnect the negative battery cable. Disconnect the positive cable.
Disconnect the 4-pin connector "A" and Black wire "B" from the alternator. See Fig. 15 .
Remove the adjusting bolt "A", locknut "B", and mounting bolt "C". Remove the alternator belt and alternator. See Fig. 16 .
Fig. 15: Disconnecting 4-Pin Connector (2.3L#
Courtesy of AMERICAN HONDA MOTOR CO., INC.
Fig. 16: Removing Alternator And Alternator Belt #2.3L)
Installation
Install in the reverse order of removal.
Adjust the alternator belt tension or the alternator A/C belt tension. See ALTERNATOR BELT and ALTERNATOR A/C COMPRESSOR BELT under ADJUSTMENT.
Enter the anti-theft code for the radio. Enter the customer's radio station presets. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
Tuesday, August 9th, 2011 AT 6:40 PM
