Electrical problems
NOUR003
  • 1993 VOLKSWAGEN JETTA
  • 1.8L
  • 4 CYL
  • 119,565 MILES
(Golf 2) every couple of days I have something disconnected like radio wipers, reversing lights and at last high light. So when I check the fuse box I had to change the problem's fuse and it would work again! I do not get it why this is happening many times until now?
is it the fuse box? Or other thing related?
Do you
have the same problem?
Friday, June 2nd, 2017 AT 5:55 AM
CARADIODOC
  • EXPERT
Your description does not make sense. It sounds like you have a fuse that is blowing intermittently; is that right? Are the circuits you listed all powered through that same fuse? What goes dead or what does not work when the fuse blows? How often does this happen? Is there anything you can identify that aggravates the problem, like hitting bumps in the road, turning the steering wheel, etc?
Friday, June 2nd, 2017 AT 10:41 PM
Recommended Guides
