Where is the ecu located on the early 2006 kia optima 5th vin digit D?
Thursday, January 24th, 2013 AT 11:18 PM
KEN L
MASTER CERTIFIED MECHANIC
the engine computer is located right on top of the transmission hump at the center of the dash.
Here is a diagram that will help you find it (below)
Cheers, Ken
Image (Click to make bigger)
SPONSORED LINKS
Monday, June 5th, 2017 AT 6:16 PM
TAMOLIT24
MEMBER
1 POST
2002 KIA OPTIMA
2.7L
V6
FWD
AUTOMATIC
Can you please tell me where the computer is located on a 2002 Kia optima lx? The emu or emc I think, please forgive my ignorance, that controls the motor or engine performance
Monday, June 5th, 2017 AT 6:17 PM
(Merged)
CARADIODOC
MECHANIC
The Engine Computer and the Transmission Computer are in the lower middle of the dash. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
(Merged)
TINASMOCK
MEMBER
1 POST
2005 KIA OPTIMA
4 CYL
2WD
MANUAL
10,500 MILES
2005 Kia Optima 4 cyl Two Wheel Drive Manual 105, 00 miles
Where is the ECU located in this car and does the ecu have to be reprogrammed if I buy a used one?
(Merged)
BLUELIGHTNIN6
MECHANIC
Yes, the ECM for the 2.7L is behind the lower center of the dash. The ECM is combined withi the TCM on the 2.4L model and is also located behind lower center of dash
SPONSORED LINKS
(Merged)
MARI-AUSTIN LADOW
MEMBER
2004 KIA OPTIMA
2.4L
4 CYL
FWD
AUTOMATIC
111,000 MILES
Can you tell me the location of the power train control module on my car?
(Merged)
CARADIODOC
MECHANIC
Thank you for listing the engine size. The locations are the same, but the modules are different. The engine/transmission computer is in the center console.
(Merged)
MARI-AUSTIN LADOW
MEMBER
Okay, thank you!
(Merged)
KEN L
Please use 2CarPros anytime, we are here to help and tell a friend.
Best, Ken
(Merged)
JOHN LEE2
MEMBER
1 POST
2004 KIA OPTIMA
2.7L
6 CYL
FWD
AUTOMATIC
123,000 MILES
The location of the ECM and how to remove it?
(Merged)
AL514
MECHANIC
The ECM is located in the lower center part of the dash, heres a diagram. Is there a reason or any help we can give as to why you are taking it out of the vehicle?
