Left side rear window?
ZUGER9Z
  • 2004 SATURN ION
  • 4 CYL
  • MANUAL
  • 57,000 MILES
How do you replace the left side rear window seal?
Wednesday, October 24th, 2012 AT 5:07 AM
SATURNTECH9
  • 30,870 POSTS
So the outter belt molding at the base of the glass on the outside of door?And the inner belt at the top of the inner door panel?
Wednesday, October 24th, 2012 AT 5:13 AM
ZUGER9Z
Yes, that is correct. The outstide belt molding on the outside AND the inner belt, both of 'em.
Wednesday, October 31st, 2012 AT 6:29 AM
ZUGER9Z
If you could provide both part numbers and instructions on how to replace I will be forever in your debt.
Wednesday, October 31st, 2012 AT 6:31 AM
SATURNTECH9
  • 30,870 POSTS
Here is the outter strips they dont give out part numbers anymore for factory parts these days. So here is the link to buy the part. I also posted the link for the inner part bellow that you can click the diagram to make sure there the correct parts your talking about, The outter stripe is easy remove the screw towards the door latch and the strip will then pop off.
Wednesday, October 31st, 2012 AT 6:00 PM
SPOCK61
  • 2004 SATURN ION
  • 4 CYL
  • MANUAL
  • 57,000 MILES
https://www.2carpros.com/forum/automotive_pictures/579841_2004_Saturn_Ion3_left_rear_window_seal_1.jpg
https://www.2carpros.com/forum/automotive_pictures/579841_2004_Saturn_Ion_3_left_rear_window_seal_1.jpg
Tuesday, July 21st, 2020 AT 2:11 PM (Merged)
SATURNTECH9
  • 30,870 POSTS
Do you have a sedan?Also which seal are you talking about?The one around the outer door?The channel run seal?The outer door seal/belt molding?Do you have picture would that help.
SPOCK61
I hAVE A SEDAN AND THE SEAL IS ON THE EXTERIOR LEFT SIDE REAR WINDON (see pic)
https://www.2carpros.com/forum/automotive_pictures/579841_2004_Saturn_Ion3_left_rear_window_seal_2.jpg
https://www.2carpros.com/forum/automotive_pictures/579841_2004_Saturn_Ion_3_left_rear_window_seal_2.jpg
SATURNTECH9
  • 30,870 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2004_ion_outer_belt_molding_part1_1.jpg
https://www.2carpros.com/forum/automotive_pictures/416332_2004_ion_outer_belt_molding_part2_1.jpg
Here you go have you found a seal yet?
SPOCK61
The new seal is on order. Thanks
KYLIEANN828
  • 2003 SATURN ION
  • MANUAL
  • 250,000 MILES
Drivers side window rolled down and will not go back up. The window is all the way down now but when I push the switch down, I still hear a click but when I push the switch up, I hear nothing. I read a lot online and I am thinking it could be a broken wire. I do not know anything about wiring or how to fix that stuff. I looked at the wire diagram and it said the blue wire is the up wire from the motor and took the door panel off and unplugged the blue wire and it looked corroded or burnt. All I really want is to get the window back in the up position and I would be a happy camper. I read about maybe "jumping" the wire, but I do not know how to do that? Can someone please help me! I is starting to get cold and rainy and I cannot have this window all the way down anymore. :(
HARRY P
  • 2,293 POSTS
I bet the problem is that the motor's brushes are stuck. Have someone hold the switch in the up position while you slam the door. Often times that will break the brushes loose and then the motor will work for a while.
If that does not do it, then you will have to pull the motor out in order to move that window up.
