Fuel pump relay location
NHMIKEY
  • 2002 MAZDA PROTEGE
  • 4 CYL
  • FWD
  • 34,000 MILES
Where is the fuel pump relay located or what does the mark look like in the fuse box? Checked web and fuse box and not marked well.
Sunday, August 14th, 2011 AT 6:09 PM
KHLOW2008
  • 41,815 POSTS
Here are the labels for the main fuse box in engine compartment. The fuel pump relay is in the main fuse panel under the hood. Fuel pump fuse is located here I will ask for help for the fuel pump relay location for you.
Sunday, August 14th, 2011 AT 7:22 PM
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,883 POSTS
Hey NHMIKEY,
Here is a diagram on the fuel pump relay locations and a test guide so when you find it you can test it to see if that is the problem:
1. Pressure regulator.
2. Quick release connector.
3. PRC solenoid valve.
4. Pulsation damper.
5. Fuel injector.
6. Fuel pump relay.
Check out the diagrams (Below). Please let us know what you find. We are interested to see what it is.
Thursday, December 29th, 2016 AT 6:03 PM
MR.CROOKHAM
  • 1999 MAZDA PROTEGE
  • 120,886 MILES
Cannot find fuel pump relay.
Thursday, December 29th, 2016 AT 6:04 PM (Merged)
IMPALASS
  • 3,112 POSTS
The information we have shows it is located in the main fuse block. Our information is not very specific. Hope this helps.
MR.CROOKHAM
You guys are awesome! That is exactly what I needed. First time user and this will not be the last you herd of me. Next time I am submitting a donation. Thank you very much!
IMPALASS
  • 3,112 POSTS
Glad we can help. Good luck on the car.
SMORDARSKI
  • 1994 MAZDA PROTEGE
  • 1.8L
  • MANUAL
  • 150,000 MILES
I need the DOHC 1.8L fuel pump relay location.
HMAC300
  • 48,601 POSTS
See picture.
TL36500
  • 1998 MAZDA PROTEGE
  • 4 CYL
  • FWD
  • MANUAL
  • 180,000 MILES
Where is the fuel relay on this car?
Wednesday, July 18th, 2018 AT 7:58 PM (Merged)
ZACKMAN
  • 4,202 POSTS
https://www.2carpros.com/forum/automotive_pictures/55316_protegedash_1.jpg
KARENFHOME
  • 6 CYL
  • FWD
  • 155,000 MILES
Recently we were advised we needed a fuel pump. The engine was cranking over, but not starting. We had already done a starter a few months ago. After the fuel pump was changed, the car no longer even cranks over. My brother advised me that I probably needed to push the reset button. He said this has to be done when the fuel pump or gas tank is changed as a safety thing. We cannot seem to locate this button. (He said it would be in the trunk on the same side as the gas tank.) Is this probably the problem? Where is that darn button located if so? Double hitter! Thank you in advance for your advice.
Tuesday, July 31st, 2018 AT 9:05 PM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle is not equipped with an inertia switch (reset button). There is a relay that controls the fuel pump through. Here is guide and diagrams of where it is located #32:
Check out the diagrams (below). Please let us know what you find.
Cheers
GREGTHOS
Thank you. It was the relay.
MSBAR
Where is the fuse for the fuel pump relay located please help me. I love this site.
Wednesday, May 19th, 2021 AT 3:26 PM (Merged)
KEN L
  • 42,883 POSTS
Here is the location of the fuse panel and relays #32. This guide will help you do some testing
and
Here are some diagrams (Below) of the fuse location
