Does not shift into second gear
DARLEEN JACKSON
  • 1998 FORD WINDSTAR
  • 4 CYL
  • 146,000 MILES
Once the car heats up and you drive for a while it wont shift into second gear. If you stop for lights or if you turn it off for a short time and restart it, it will just stay in first
and the speedometer will stay at zero. Sometimes it will start going eventually, but other times it has to be shut down and not driven for a little while before it will drive regular again. Do you know what is causing this problem?
Do you
have the same problem?
Tuesday, August 9th, 2016 AT 6:22 PM
KEN
  • ADMIN
Hi DARLEEN,
First I would check the fluid level, then it sounds like the vehicle speed sensor VSS is going out.
Here is a part for you
https://www.amazon.com/gp/search/ref=as_li_qf_sp_sr_il_tl?ie=UTF8&tag=2carprcom-20&keywords=1998-FORD-WINDSTAR-vehicle-speed-sensor&index=aps&camp=1789&creative=9325&linkCode=xm2&linkId=5c98c941d4028a33d89baf630da4036e
Let me know what you find
Best, Ken
Friday, August 12th, 2016 AT 10:33 AM
Recommended Guides
