Map sensor
RICHSRIDE
  • 2001 DODGE TRUCK
  • 6 CYL
  • 4WD
  • 65,000 MILES
Where is the map sensor located?
Saturday, May 23rd, 2009 AT 10:57 PM
BMRFIXIT
  • 19,053 POSTS
Manifold Absolute Pressure Sensor (3.9L)On front of throttle body Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_367.jpg
Saturday, May 30th, 2009 AT 5:27 AM
TAZMAN05
  • 1999 DODGE TRUCK
  • V8
  • 190,000 MILES
Where is the map sensor located on the 5.9L engine?
Saturday, December 19th, 2020 AT 9:55 AM (Merged)
The map sensor is near the top of the engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/12900_map_2.jpg
TEVERETT
  • 1998 DODGE TRUCK
  • 6 CYL
  • 4WD
  • MANUAL
  • 245,000 MILES
Where is the map sensor located on my 1998.5 Dodge ram 2500 24 valve turbo deisel?
BLUELIGHTNIN6
  • 16,542 POSTS
The MAP sensor is fitted to the front of the throttle body except on 4.7L and 8.0L engines where it is installed on the intake manifold.
Thanks for using 2CarPros. Com!
