1995 Dodge Truck won't stay running
TODDOG
  • 1995 DODGE TRUCK
Seems like the problem lies in the computer plugin somewhere if you hold it a certain way the truck will run but if you move it the truck will stall, also if you turn on the a/c it will stall, I have had this problem since my coil wire fell and hit the manifold and burnt in two, can anyone help me with this problem, thank you toddog
Do you
have the same problem?
Thursday, August 23rd, 2007 AT 6:10 PM
BMASTERJERRY
Check ignition timing.
Friday, August 24th, 2007 AT 8:53 PM
Recommended Guides
