2004 Dodge Stratus engine light
LPEREZGARCIA
  • 2004 DODGE STRATUS
  • 4 CYL
  • FWD
  • 99,000 MILES
I have a dodge stratus 2004 2.4L dohc and my engine light keeps turning on. I took it to a car shop and was told that my catalytic converter is broken so it kept breaking my oxygen sensor. I replaced the cat and the sensor and disconnected the battery and it was off for about a day then it turned back on what do you thing the problem is? Do I need to have it cleared by a store like autozone?
Do you
have the same problem?
Wednesday, July 14th, 2010 AT 9:59 PM
  • EXPERT
I would recommend having the computer rescanned to see if it is the same code. Did you do the work or was it done at a shop?
Saturday, July 17th, 2010 AT 12:21 AM
LPEREZGARCIA
A shop changed the catalytic converter but I changed the sensor.
Thursday, July 22nd, 2010 AT 7:18 PM
  • EXPERT
Have a parts store scan the computer and let me know what code is coming on. Have them reset the check engine light to see if it comes back on. It should be done with a scanner.
Friday, July 23rd, 2010 AT 12:07 AM
Recommended Guides
