2001 Dodge Stratus fuel
BEANFLICKERE
  • 2001 DODGE STRATUS
  • 6 CYL
  • 225,000 MILES
I have posted this already but may have not said it all the right way. The car was runniing just fine. Than it starting bucking. Than died. Put in fuel pump. Than cam sesor. The car started but big clouds of smoke. You could just smell the gas badly. Put in a new regulator the car is still dumping fuel bad just pouring out the tail pipe. Is it possable for all the injectors to be stuck open. Or is it the computer.
Do you
have the same problem?
Monday, February 2nd, 2009 AT 2:44 AM
BMRFIXIT
  • EXPERT
Suspect injectors
check the pulse
Monday, February 2nd, 2009 AT 6:53 AM
Recommended Guides
