Engine keeps overheating?
STEPSIDE
  • 2001 DODGE STRATUS
  • 99,000 MILES
Changed water pump, heater core, thermostat, how can I check to see if it has a blown head gasket, that is blowing compression back into the cooling systemand heater will not blow hot air
Sunday, May 13th, 2012 AT 5:34 PM
  • 52,797 POSTS
You need a leak down test in the cylinders to verify. from your description, it sounds like you have issues.
Can you go over this guide it can help us fix it
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Sunday, May 13th, 2012 AT 5:35 PM
STEPSIDE
  • 5 POSTS
Does not smoke. Just did tune up, changed distributer, cap, wires, plugs, crank pos. Sensore, rough idle about 500 rpm.
Sunday, May 13th, 2012 AT 5:41 PM
STEPSIDE
  • 5 POSTS
Heater does not blow hot
Sunday, May 13th, 2012 AT 5:42 PM
  • 52,797 POSTS
Get the leak down test done before throwing anymore at tit.
Sunday, May 13th, 2012 AT 5:50 PM
STEPSIDE
  • 5 POSTS
What type of pressure gauge do I need, can I get it from parts store, or form snap-on tools
Sunday, May 13th, 2012 AT 5:53 PM
  • 52,797 POSTS
It is cheaper to have it done by a shop
Sunday, May 13th, 2012 AT 6:02 PM
STEPSIDE
  • 5 POSTS
Don't trust the car to leave the yard, thanks for the help, don't have the money for a shop
Sunday, May 13th, 2012 AT 6:09 PM
  • 52,797 POSTS
Can you tow it to a shop? Most likely you have a blown head gasket especially when there is no heat.
Sunday, May 13th, 2012 AT 6:21 PM
XRMOORE
  • 162,000 MILES
My car overheats when idle for a while but returns to normal temperature when I am driving. The radiator, hoses, and thermostat were all changed within the past 3 weeks. The car went into the red about a month ago, which prompted me to change the thermostat. Then the radiator began to leak, so I changed it as well as the hoses.
Saturday, December 5th, 2020 AT 10:05 AM (Merged)
SATURNTECH9
  • 30,870 POSTS
Sounds like the radiator cooling fan isnt working does that come before or during the time its running hot at idle?
XRMOORE
The fans work perfectly. I checked them this morning when the temp gauge began to rise.
SATURNTECH9
  • 30,870 POSTS
So both upper and lower radiator hoses are getting really hot?When the fan comes on is there a lot of air being pulled thru the radiator?If you were to feel. With your hand iam talking?What is the actual temp the radiator fan is coming on at?
XRMOORE
Both are getting really hot. I haven't checked the actual temperature, but I will later today and let you know what I find out.
SATURNTECH9
  • 30,870 POSTS
Alright keep me posted.
ALLIECEE
  • 4 CYL
  • 123 MILES
My dodge stratus 2001 is overheating recently. About a month ago it overheated for the first time and we realized it was completely out of coolant. We didn't find it odd seeing we hadn't replaced the coolant in years but in little less than a month it is completely out of coolant again and overheating once again. We have checked for leaks. The radiator also seems to not have any coolant in it at the moment so the coolant isn't circulating through the system. What is the problem?
Check the thermostat and water pump
PROTECH1980
  • 901 POSTS
Get the coolant system pressure tested to find the source of the leak, the coolant is going somewhere, If it is overheating and boiling the coolant out, check and test coolant fans, thermostat, and get a chemical test done to check for combustion gases in the coolant(head gasket/ head problem)
DEEDEE2009
  • 7 POSTS
  • 2.4L
  • 4 CYL
  • 180,000 MILES
My car started overheating, smoke under hood. There was some antifreeze on the ground once the car was parked and shut off for a while even though the overflow container has plenty of antifreeze in it. Now the next day when we tried to start it, it makes a whirring sound. The belts are turning, so I think the motor didn't seize. Maybe it's not getting fuel? Could the starter have fried because of overheating?
Thank you for your response.
  • 108,133 POSTS
Does the starter sound like it's spinning too fast? Also, how hot did it get (in the red zone of the gauge) and how long did you run it that way? Finally, can you tell aprox where the coolant was leaking from?
CURLYGIRL
  • 4 CYL
  • 165,000 MILES
First my heater quit working and then the car started overheating and dumping out all of its coolant. How do I replace the thermostat and where is it?
