Camshaft position sensor location and replacement?
ANONYMOUS
  • 2006 DODGE STRATUS
  • 100,000 MILES
How do you change the Camshaft sensor on a 2006 Dodge Stratus. I believe the engine is a 2.4.
Saturday, December 1st, 2012 AT 9:48 PM
  • 52,797 POSTS
CAMSHAFT POSITION SENSOR
REMOVAL
The camshaft position sensor is mounted to the end of the cylinder head.
Remove the negative battery cable.
Disconnect the PCV hose and reposition.
Cam Sensor/EGR Valve/PCV Valve
Disconnect electrical connectors from the camshaft position sensor.
Remove camshaft position sensor mounting screws. Remove sensor.
Target Magnet Removal/Installation
Loosen screw attaching target magnet to rear of camshaft and remove magnet.
INSTALLATION
Target Magnet Installation
The target magnet has locating dowels that fit into machined locating holes in the end of the camshaft.
Install target magnet in end of camshaft. Tighten mounting screw to 3 N.M (30 in. Lbs.) Torque. Over torqueing could cause cracks in magnet. If magnet cracks replace it.
Install camshaft position sensor. Tighten sensor mounting screws to 13 N.M (115 in. Lbs.) Torque.
Carefully attach electrical connector to camshaft position sensor. Installation at an angle may damage the sensor pins.
Connect the PCV Valve hose.
Connect the negative battery cable.
Saturday, December 1st, 2012 AT 9:59 PM
J WASKO
  • 76,000 MILES
My engine light came on, machine check said cam shaft sensor. Car bucks like it is not getting gas or there is water in the gas. Seems to be worse when going uphill. I changed the sensor. Still having same problem. Machine check is still saying cam shaft sensor. Frustrated
Saturday, November 28th, 2020 AT 4:17 PM (Merged)
  • 52,797 POSTS
First, a code number never identifies a bad part, just a failed system.
Anyway, many issues with the wiring on these cam sensors being soaked with oil and the wires loosing there insulation and shorting together. Remove the connector and uncover the harness about 12-14 inches and I bet you find this issue.
CARADIODOC
  • 33,738 POSTS
Fault codes never say to replace parts. The codes tell you which circuit needs to be diagnosed further. It's true that about half the time the sensor is the cause of the problem but you also have to look at the wiring and in particular, the connectors. Look for loose or corroded pins first. Next, perform electrical measurements at the sensor. How those tests are done depends on which engine you have.
Check the sensor's resistances, getting an input signal and returning it back to the computer-
AMSORONDO
  • 2004 DODGE STRATUS
  • 6 CYL
  • FWD
  • 165,000 MILES
I need HELP finding the camshaft sensor location. I have and need to replace the sensor but I'm having a little trouble finding it. Can anyone help?
Saturday, November 28th, 2020 AT 4:18 PM (Merged)
RICHZOMBIE
  • 173 POSTS
This is for a 2.4l
https://www.2carpros.com/forum/automotive_pictures/307763_Noname_5.jpg
This is for a 2.7l
https://www.2carpros.com/forum/automotive_pictures/307763_Noname_6.jpg
SHEREA06
  • 4 CYL
  • FWD
  • 56,000 MILES
Where is a camshaft position sensor located?
Its at left rear of engine. Check out the diagrams (Below). Please let us know if you need anything else to get the problem fixed.
https://www.2carpros.com/forum/automotive_pictures/12900_chm_1.jpg
MEOSHI
  • 6 CYL
  • FWD
  • 22,000 MILES
Where is the cam sensor located on a 2004 Dodge Stratus.
BMRFIXIT
  • 19,053 POSTS
Cam position sensor V6 2.7l engine is located at front of engine at the cylinder head
https://www.2carpros.com/forum/automotive_pictures/99387_Graphic1_58.jpg
CHUCK3737
  • 2003 DODGE STRATUS
  • 4 CYL
  • FWD
  • 66,000 MILES
I got a 2003 dodge stratus and the code turned out to be my cam sensor. Changed it 2 times! I get to 2200 rpm and the car loses power and jerks.I turn it off then restart it and it is fine 4 a bit. Some times it wont start after this problem happens so I have to shake the the wires that go to my cam sensor and it seems fine. Please help.I need this car to get my son to school.
BMRFIXIT
  • 19,053 POSTS
Its a cam sensor and not a crank sensor?
What do you have for codes?
CHUCK3737
Im not sure but the tec told me it was my cam sensor but I have changed it twice. Sometimes I have to shake the wires cumin out of the plugin on the cam sensor and then the car runs fine for a little while
BMRFIXIT
  • 19,053 POSTS
That is an indication of a bad wire and or connector
CHUCK3737
Just wanted to say thanks.
TOPGUN20
  • 4 CYL
  • FWD
  • 70,000 MILES
Where is the camshaft positioning sensor located?
BMRFIXIT
  • 19,053 POSTS
Here is a guide to help walk you through the steps of replacing the sensor and a diagrams below to show you no your car.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
https://www.2carpros.com/forum/automotive_pictures/99387_dodge_24_1.jpg
CRZYBYTCH623
  • 2002 DODGE STRATUS
Electrical problem
2002 Dodge Stratus Automatic
where is the cam sensor located
Saturday, November 28th, 2020 AT 4:19 PM (Merged)
2CARPRO JACK
  • 11,533 POSTS
2.4 l it is located at the end of the head on the end of the cam
https://www.2carpros.com/forum/automotive_pictures/1639_24_1.jpg
2.7 L it is located on the front of the engine at cylinder head
https://www.2carpros.com/forum/automotive_pictures/1639_27_1.jpg
