2000 Dodge Stratus no spark to 3&4 cylinder
CFK3366
  • 2000 DODGE STRATUS
  • 4 CYL
  • FWD
  • 91,763 MILES
Well first of all the water pump went out so we desided to change water pump and timing belt spark plugs/wires the car sat down for about a year before I got it but from what the last owner told me tht thy changed all those iteam so I did the check and everything seems to be in order but now im having problems with firing in 3&4 cylinder have no spark 1&2 is firing ok but looks like the 1&2 will soon follow 3&4cause by looking at the plugs its not like its really burning like it should it had a browndish look and the top of the elctrode not tht clean ash look like the plugs are firing do I hve re do the timing again I checked the timeing marks and seem to be fineand would it be why its not firing in 3&4 help would be nice Aloha
Do you
have the same problem?
Thursday, October 1st, 2009 AT 3:20 AM
BMRFIXIT
  • EXPERT
Suspect bad coil
also do a compression test
Thursday, October 1st, 2009 AT 6:29 PM
Recommended Guides
