Blower motor resistor
FIVER5TER
  • DODGE STRATUS
Blower motor is working on high only, know that it is the resistor, but exactly where is this located?
Sunday, January 28th, 2007 AT 1:56 PM
SERVICE WRITER
  • 9,123 POSTS
Passenger side bottom of the HVAC plenum
See diagram below for location
Sunday, January 28th, 2007 AT 7:51 PM
MIKE MCCORMICK
  • 1998 DODGE STRATUS
Heater problem
1998 Dodge Stratus 4 cyl Two Wheel Drive Automatic
part #1-04885844AA
the fan works on high only, dealer replaced resistor
in July
Monday, December 31st, 2018 AT 10:28 AM (Merged)
BLUELIGHTNIN6
  • 16,542 POSTS
Check for faulty blower motor relay
BAS0511
  • 1999 DODGE STRATUS
  • 4 CYL
  • FWD
  • 111,000 MILES
My heater only works on high so I got a new blower moter resistor but I can't find where it is on the car to replace it. Looked ynder dash and behind glove box without any luck. Please help
ZACKMAN
  • 4,202 POSTS
Yes it is there. Just next to the blower motor.
Look at this picture.
https://www.2carpros.com/forum/automotive_pictures/55316_blowerrepair_1.jpg
And go to www.stratusphere.us/blowerrepair.html for instruction.
TTBUMPS
  • 2000 DODGE STRATUS
  • 6 CYL
  • FWD
  • 120,000 MILES
I need to know where the blower resistor is located on a 2000 dodge stratus so that I can replace it
OBXAUTOMEDIC
  • 3,711 POSTS
It is located in the duct work under the passenger dash.
RADARR111
Electrical problem
1998 Dodge Stratus 4 cyl Front Wheel Drive Automatic 197564 kms
I'm asking how to replace the blower resistor. I have been told it is in behind the dash board. Is this correct? And if so, the procedure for replacing it.
Thanks
The blower motor resistor is located on the lower right side of the heater housing.
REMOVAL
Remove lower right underpanel silencer/duct.
Disconnect wiring connectors on blower motor resistor.
Remove blower motor resistor retaining screws.
Blower Motor Resistor
https://www.2carpros.com/forum/automotive_pictures/12900_b_18.jpg
Pull blower motor resistor out of heater housing.
INSTALLATION
For installation, reverse the above procedures.
https://www.2carpros.com/kpages/auto_repair_manuals_alldata.htm
MTSMGS
  • 6 CYL
  • 165,000 MILES
2000 dodge stratus se 2.5l blower and temp controm problem
Hi, The afore mentioned vehicle has only (4) highest speed working on blower switch. Also, temp knob doesn't regulate the temp at all. Where is the resistor located for the blower and how do I fix the temp switch. Thank you very much for your time and input!
SERVICE WRITER
  • 9,123 POSTS
https://www.2carpros.com/forum/automotive_pictures/30961_strres_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_strres1_1.jpg
MTSMGS
Thanks for the advise. I changed the resistor and now all 4 fan speeds work, however, the temp control knob still doesn't change the temp of blower air. Can't hear any sound when I turn it, (like a door opening and closing) control motor for temp switch?
Also not sure where it is. Any ideas would be appreciated.
Hanks again for your help.
Mike
SERVICE WRITER
  • 9,123 POSTS
I assume you tried to calibrate it? If not do so first.
https://www.2carpros.com/forum/automotive_pictures/30961_mode_1.jpg
https://www.2carpros.com/forum/automotive_pictures/30961_mode1_1.jpg
JGUMINA
  • 4 CYL
  • FWD
  • 160,000 MILES
It just happened today. When I select the speed of the fan the only time the fan works is in high speed only when I turn the knob selection to high it has off. It that is the fan selection switch has 4 speeds. Like I said it only works now on high blowing. What can I do
ZACKMAN
  • 4,202 POSTS
Here is a write-up that my have kindly done for you.
https://www.2carpros.com/articles/mitchell1eautorepair-car-repair-manuals
