1997 Dodge Stratus Harmonic Balancer {How to remove}
SHELDONW
  • 1997 DODGE STRATUS
  • 4 CYL
  • 17,500 MILES
How do I remove the harmonic crank pulley
Do you
have the same problem?
Tuesday, August 18th, 2009 AT 7:39 PM
HUNGARIAN1234
You use a small 3 jaw wheel puller. DO NOT use a large puller on the outer ring of the Harmonic balancer as you will pull the outer ring off of the inner ring and ruin it. The jaws should be able to go through the cutouts in the balancer.
Tuesday, August 18th, 2009 AT 9:01 PM
MULDOON
Advance Auto will give you that puller free on loan but I needed a 6 inch straight piece of metal rod to use also its not that hard but check hayes manual
Thursday, September 10th, 2009 AT 2:23 AM
Recommended Guides
