Fuel pump
NICKYBULL82
  • 2003 DODGE STRATUS
  • 6 CYL
  • FWD
  • MANUAL
  • 90 MILES
Wheres the location of the fuel pump can I take the seat out or do I gotta take the tank out
Saturday, December 18th, 2010 AT 5:17 PM
DOCFIXIT
  • 18,828 POSTS
Your lucky day remove rear seat then access cover remove fuel module. Here is a guide to help you step by step with diagrams below to show you how on your car.
https://www.2carpros.com/articles/how-to-replace-an-electric-fuel-pump
Saturday, December 18th, 2010 AT 5:47 PM
1DERHUNTER
  • 1999 DODGE STRATUS
  • 4 CYL
  • 170,000 MILES
Is there emergency shut switch and reset for fuel pump if so where can I find it? Thanks
Monday, March 25th, 2019 AT 5:05 PM (Merged)
  • 108,170 POSTS
No shut off. There is a fuel pump relay. Is the pump not working? Have you checked for power to it?
JBLECK
  • 18 POSTS
  • 1998 DODGE STRATUS
Can anyone tell me exactly where the fuel pump modular connector is in a 1998 Dodge Stratus 2.5L V6? I have looked where the Haynes manual says it is located, in the trunk left side.
I have located a connector but it is not the fuel pump modular connector (at least I think it's not). I sure could use a picture (preferably in color) of the location or maybe a picture of the fuel pump modular connector itself. Thanks
JBLECK
  • 18 POSTS
Also, are the fuses in the PCM supposed to have a voltage reading whether the ignition is in the ON or OFF position?
CARADIODOC
  • 33,738 POSTS
Maybe I can help you. What are you trying to do or what is the symptom / problem? I never needed to find a connector so I might have a better approach to what you're up to.
JBLECK
  • 18 POSTS
I am not hearing the fuel pump engage when the key is in ON position.
CARADIODOC
  • 33,738 POSTS
How long are you expecting to hear it? The pump should only run for one second, then again during engine cranking. If you don't hear it or can't hear it over the chime, you can bypass the fuel pump relay to make it run all the time so you can troubleshoot the circuit if necessary.
JBLECK
  • 18 POSTS
Can you explain how to bypass the fuel pump relay to make it run all the time please?
CATFISH1971
  • 1996 DODGE STRATUS
  • 4 CYL
  • FWD
  • 158,000 MILES
Where is the fuel pump located at on a 1996 dodge stratus
LEGITIMATE007
  • 5,121 POSTS
Hey catfish, the pump is inside the gastank unfortunately, some vehicles can gain access to it through the back seat, but I dont think yours does, but I could be wrong.
CARADIODOC
  • 33,738 POSTS
Use the sad drawing on the right. Your fuel pump relay is the third small one from the end furthest away from the four big relays. I'm making a drawing right now to show the layout of the fuse box if you need it.
Use a piece of wire or a stretched-out paper clip to jump the two terminals shown with the arrows. The ignition switch doesn't have to be on.
JBLECK
  • 18 POSTS
Ok. Now everything seems to be checking out the fuel pump is coming on and the car will start when I spray starting fluid in the throttle the car will start but will not continue to idle. I'm getting spark but it seems to be weak. Any ideas?
CARADIODOC
  • 33,738 POSTS
I guess I'm confused. Is the pump running because you jumped the relay or is it running on its own like normal? If it's running, you shouldn't need starting fluid unless the injectors aren't being fired. What I would do next is check for diagnostic fault codes to see if you're missing the signal from the camshaft or crankshaft position sensors. Cycle the ignition switch three times from "off" to "run" without cranking the engine, then watch the code numbers show up in the odometer display.
BUDDHALUV79
  • 42 POSTS
  • 1995 DODGE STRATUS
  • 4 CYL
  • 200,000 MILES
My fuel pump is out I believe.I have heard that some dodge's you can get to it from the back seat but not sure if you can on a 1995. So I was just wondering if it is located in the actual tank and how hard is it to change it? Thank you for any help.
Monday, March 25th, 2019 AT 5:06 PM (Merged)
  • 52,797 POSTS
REMOVAL
Remove fuel filler cap and perform Fuel System Pressure Release procedure. See: Fuel Pressure Release Service and Repair
Disconnect negative cable from auxiliary jumper terminal.
Remove fuel tank. Refer to Fuel Tank/Service and Repair.
Disconnect fuel filter lines from fuel pump module.
Clean top of tank to remove loose dirt and debris.
Using Special Tool #6856 Fuel Pump Module Ring Spanner, remove locknut to release pump module Fig. 10.
WARNING: The fuel reservoir or the fuel pump module does not empty out when the tank is drained. The fuel in the reservoir may spill out when the module is removed.
Sorry, the tank must be removed.
BUDDHALUV79
  • 42 POSTS
Thank you so much for your help!
  • 52,797 POSTS
Good luck
BUDDHALUV79
  • 42 POSTS
Ok, so we got the tank dropped and took the old fuel pump out and the fuel pump is good. It just for some reason is not kicking on when you turn the ignition. We also checked the hook up plug where the fuel pump connects under the seats and that is also getting juice. We checked it with a (not sure what it is called) voltage meter or whatever and it is active at that connection. And we also hooked the fuel pump up to this same contraption and the motor turns on. It just does not turn on for some reason when we hook it up to the car. Any suggestions on why it is not kicking on? We also tried the fuel relay switch to make sure it was good, and it is. For some reason the pump just has stopped kicking on when we try to start the car.
  • 52,797 POSTS
Just because it turns does not mean it produces the required pressure to start the car. What is the pressure?
Also, if I read this right, you are saying when you hook it up to the car harness, it does not work. The pump will prime for 2 seconds when the key is turned on, it will turn back on when there is a signal that the motor is turning or running. You need to verify this as well. Was there any power to the pump from the car harness?
