1995 Dodge Stratus not swichting
JBUS725
  • 1995 DODGE STRATUS
  • 6 CYL
  • FWD
  • 108,000 MILES
When switching from deforst to floor it stays on defrost have changed switch does make a drifferance will I have to take dash off to find the oroblem
Do you
have the same problem?
Saturday, October 11th, 2008 AT 9:33 AM
  • EXPERT
Hi:
It sounds like the blender door isn't working. On your vehicle look under the dash (near center) and find a vacuum diaphragm that runs the door. Check to make sure it's getting vacuum. If it is, watch if it functions when moving from one position to another. If it isn't have remove it and have it checked.
Before you do that, are you getting vacuum to the switch you replaced?
Wednesday, October 22nd, 2008 AT 10:44 AM
Recommended Guides
