1994 Dodge Spirit No Compression
ATISCIONE
  • 1994 DODGE SPIRIT
  • 6 CYL
  • FWD
  • 137,500 MILES
I was told my car has no compression. It was running and stalled, and would not start again.
Do you
have the same problem?
Tuesday, April 21st, 2009 AT 7:52 PM
BLACKOP555
  • EXPERT
Have you performed a compression test on it?
Before doing that disconnect the fuel system and the ignition ssytem. Then give 7 good cranks per cylinder and record highest reading. Lowest cylinder should be no more then 30% les then highest cylinder.
Add oil in cylinders foudn low. Does that dramatically increase the compression? Let me know what you find.
Wednesday, April 22nd, 2009 AT 8:38 PM
Recommended Guides
