Speedometer
TBG
  • DODGE RAM
I have both a 1997 and 1998 Dodge Ram 1500 Club cab. Both with 5.2L Automatic both over 175000 miles. I had the transmissions swaped. The 97 transmission had no problems with the 98 truck but the 98 transmission in the 97 truck, the mechanic said the connector was different and the speedometer dosent work. Alll parts catalogs say the parts are identical. Could the vehicle speed sensor be bad?
Do you
have the same problem?
Sunday, August 19th, 2007 AT 3:51 PM
DIPWEED23
Likely your speed sensor is bad then.
Monday, August 20th, 2007 AT 5:44 PM
Recommended Guides
