Fuel problem
RAMW150
  • DODGE RAM
Hello I have a 1985 dodge ram w150 318 4bbl carb 4x4 i've been having this fuel problem for awhile now i've tried everything from replacing the fuel pump carb fuel lines it starts and idles fine it's when I start to drive it down the road the motor boggs down like carb is running out of fuel it ssat up from augt 06 till 6-23-07 I got it back on the road on 6-23-07 ran fine didn't bogg down and it ran fine also on 6-24-07 I was able to drive to work which is 12miles from where I leave but it started to bogg down today and I only drove 5 miles down the road from my house it will run off of a eletric fule pump I also fill my 2 gallon gas can up and hook the mec pump to the 2 gallon gas can and it sucked the gas can dry can someone help me this is my only means of transportion
Do you
have the same problem?
Monday, June 25th, 2007 AT 10:52 PM
BIGDADDYWEST
Sounds like youre converter is stopped up.
Wednesday, September 26th, 2007 AT 7:48 PM
Recommended Guides
