2005 Dodge Ram Starting issues
CHUCK3132003
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 100,000 MILES
My truck occassionally will not start until the second or third key turnover, is thisa problem with the fuel filter or regulator?
Do you
have the same problem?
Wednesday, October 20th, 2010 AT 11:07 PM
  • EXPERT
It could be either. What you need to do is check the pressure and fuel pressure drop off. It could be loosing its prime causing the problem. Here is a how to for checking the pump, regulator, and drop off. You will need a gauge, but most parts stores will lend or rent them.
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
joe
Wednesday, October 20th, 2010 AT 11:12 PM
Recommended Guides
