Overheating
PDCON37
  • 2005 DODGE RAM
  • 3.8L
  • V6
  • 60,000 MILES
My truck over heats on hot days or when towing my wave runner, its ok on cooler days. I have replaced the tstat and water pump, have changed the coolant and made sure to burp it really well, also flushed the radiator. Please help
Friday, June 12th, 2020 AT 12:02 PM (Merged)
HMAC300
  • 48,601 POSTS
Check radiator for cold spots with fan disconnected and engine hot and off. If you feel any cold spots radiator is no good and needs replaced. Otherwise have coolant system pressure checked for internal leaks.
GWINFIELD2
  • 2005 DODGE RAM
  • V8
  • 4WD
  • 109,000 MILES
Truck overheated on highway. Turned out that radiator cap was loose and I lost fluid. Refilled radiator and reservoir started truck but was still overheating. Shut off truck waited a while restarted truck still ran hot, but I gave the radiator hose a squeeze and temperature went back to normal. Was it possibly an air pocket? Or is my thermostat going bad?
CARADIODOC
  • 33,737 POSTS
This apparently was caused by the loose radiator cap, and that is not going to damage the thermostat. You are right about the air pocket. I do not know why you did not list the engine size when you have an engine-related problem, but the V-8 engines usually self-bleed by themselves. If it is necessary to bleed the cooling system, there will usually be a bleeder screw on the thermostat housing. When there is not, look for a threaded plug or a temperature sensor on or near that housing that can be removed. If you need to remove a sensor, unplug it and do that while the ignition switch is off to avoid setting a diagnostic fault code that could confuse someone in the near future. Most fault codes self-erase after fifty engine starts, but it is easier to just avoid setting them in the first place.
GWINFIELD2
Thanks. Sorry about forgetting to list engine size. Appreciate the feedback.
KEN L
  • MASTER CERTIFIED MECHANIC
  • 42,877 POSTS
Please let us know happens so it will help others.
Best, Ken
