2003 Dodge Ram No Start
ECREEK
  • 2003 DODGE RAM
Engine Performance problem
2003 Dodge Ram V8 Two Wheel Drive Automatic
5.9 engine, JTEC pcm. No start. +5volts ref output from pcm is only 2 volts and decreases to ~1.7 v while cranking. + The fuel pump doesnt energize and the auto shutdown relay doesnt energize either when key is rotated to RUN before START.
Wednesday, June 24th, 2009 AT 11:41 AM
RACEFAN966
  • 5,029 POSTS
Ok so tell me have you checked fuse number 2 and number 17 and 19? These all in some way tie into the fuel pump and shut down relay. If these are good then I need you to check the light green wire with the black stripe going to the fuel pump relay and let me know if you have power there with key on engine off. Get back to me with what you find.
Friday, June 26th, 2009 AT 10:15 AM
ECREEK
  • 11 POSTS
Fuse #2 to the ASD relay is OK. Fuse #17 to the Fuel Pump Relay conntact (30) is oK. Fuse #19 supplying +12V to the PCM, C1-22 is OK. The LG/BK wire going to the Fuel Pump Relay is providing the +12V to the Relay Coil. I cut the BR Relay Coil wire going to the PCM & clipped it to Ground. The Pump ran & produced 50+ PSI. The PCM wasn't pulling this BR to Ground during crnking. The relays are both good. I swapped them & can still get the Pup to run when grounding the snipped BR wire.
Friday, June 26th, 2009 AT 8:37 PM
RACEFAN966
  • 5,029 POSTS
You need to fix the br wire it must have a short in it. It is suppose to go to the computer the power train module pin number 19. SO check continuity from one point to the other and fix that problem and the pump should work as it is suppose to unless the computer isn't sending the signal then you have a bad computer.
Saturday, June 27th, 2009 AT 8:45 AM
ECREEK
  • 11 POSTS
Do you have any thoughts on the +5 V PCM supply (C1-17) output being only +2V?
Saturday, June 27th, 2009 AT 10:02 AM
RACEFAN966
  • 5,029 POSTS
PCM supply voltage to what? Where is C1-17? My references don't show that.
Wednesday, July 1st, 2009 AT 8:46 AM
ECREEK
  • 11 POSTS
C1-17 is a 5 Volt Refernce that the PCM outputs to several sensors; Cam sensor, Crank sensor, MAP, to name 3. I think it powers more sensors such as TPS.
Wednesday, July 1st, 2009 AT 10:33 AM
RACEFAN966
  • 5,029 POSTS
Ok so tell me do you have any trouble codes set? Is the battery at a full 12 volts. Are you getting power to the auto shut down relay and power out of it? Let me know what you find.
Thursday, July 2nd, 2009 AT 9:03 AM
ECREEK
  • 11 POSTS
I periodically charge the battery to full capacity. The ASD is not being energized (pulled to ground) by the PCM. The ASD relay (and the Fuel Pump relay) are both OK as I indicated in a previous post. I cant get the PCM to issue any trouble codes except an ERR message that shows up on the OBD II reader.
Thursday, July 2nd, 2009 AT 10:07 AM
RACEFAN966
  • 5,029 POSTS
So do you have power to the auto shut down relay? Have you checked fuse number 2 (30amp) in the under hood fuse box? The computer does not pull the auto shut down relay to ground the ignition powers it up it grounds through the chassi according to the wiring diagram I am looking at. It sends power to a number of points. I also need you to check fuse number 28. What else on the truck don't work?
Looking at the engine performance wiring diagram I need you to check fuse 17 (15amp) and fuse 49 (20amp) these power the fuel pump and auto shut down too. I also would like to know if the light green wire with the black stripe at the fuel pump relay gets power with the key on. Do you have spark? Check ptc 1 (7.5amp fuse) in the under hood fuse relay box. I also would like to know if the dark blue wire with the yellow stripe at the auto shut down relay has power with key on, and then the brown wire at the fuel pump relay does it get power with key on? Let me know what you find and we will go from there.
Friday, July 3rd, 2009 AT 9:16 AM
ECREEK
  • 11 POSTS
Yes & Yes for 1st 2 qyuestions. I indicated this in a previous post. The ASD relay coil (terminal 85) gets +12V thru fuse #2. The other side of the coil (terminal 86) goes to the PCM C3-3 (auto shutdown relay control), not chassis ground. I tracked the DB/YL wire & verified this.
All fuses are good. They have been checked at least twice each.
As far as what else doesn't work, evrything else checked works such as lights, radio, signals, etc.
Fuse 17 & 49 are good. The LG/BK wire has power with the key ON.
Sunday, July 5th, 2009 AT 10:21 AM
RACEFAN966
  • 5,029 POSTS
Well I don't like to say a computer is bad but it sounds like you may have just that. If I remember right you checked the reference voltage to the tps and map sensors and such and they are all low?
Monday, July 6th, 2009 AT 1:04 PM
ECREEK
  • 11 POSTS
Yes. The +5V reference is reading only +2V with the key ON
Monday, July 6th, 2009 AT 1:46 PM
RACEFAN966
  • 5,029 POSTS
Ok would you make a jumper wire and ground the computer case and see if anything changes. Let me know what happens.
Monday, July 6th, 2009 AT 1:56 PM
DANNYGAR 613
I have the same problem the truck would just turn off running and would not turn bac on for hours I also bought the gas pump, crank and cam positioning sensors and the diagnostic computer was reading clogged catalytic converter or vacume leak, my truck is a 2003 with 74k mles. In my case apparently it something loose in the fuse box. I just dicovered this a few minutes ago it started to rain while I was working on the truck and the wipers wouldnt start nor the truck would turn on but it would crank. I accidentaly tapped the fuse box and the wipers came back on and I tried to turn on the truck and it turned on instantly. Now I noticed thatt if the wipers dont work the fuel pump wont work either. Im not saying that the wipers have to be on for the pump to work but when I see that the wipper stops working so will the pump. Im going to look around the fuse box and see if I see something loose.
Friday, June 1st, 2012 AT 10:18 PM
RACEFAN966
  • 5,029 POSTS
I would think either the fuse box is getting wet inside the plug or maybe there is a windshield leak that is allowing water to get on the body module. Is there any moister inside that isn't normal?
Tuesday, June 19th, 2012 AT 4:48 PM
