2003 Dodge Ram crank sensor
VOLKS WILLY
  • 2003 DODGE RAM
Electrical problem
2003 Dodge Ram 6 cyl Four Wheel Drive Automatic
Can the crank sensor burning out burn out the skim module for the alarm system. The truck is a deisel it started right up then in about a minute it shut off, it turned over no problem but pulled up the codes it read p0633 so they changed the skim module, then they said it must be the crank sensor. They changed that still nothing now looking at the pump and said no pressure. When I opened the tap for moisture in the filter there was pressure no water.
Do you
have the same problem?
Friday, January 29th, 2010 AT 9:38 AM
  • EXPERT
Lets start with the basics. Is the engine getting spark and fuel? Here are the how to's for checking. Check them and let me know what you find. Also, let me know if the check engine light was on when it was running.
http://www.2carpros.com/how_to/how_to_test_an_ignition_system.htm
http://www.2carpros.com/how_to/how_to_check_fuel_pressure.htm
Let me know what you find.
Tuesday, February 2nd, 2010 AT 10:37 AM
Recommended Guides
