2002 Dodge Ram heater problem
RAM GUY1
  • 2002 DODGE RAM
2002 Dodge Ram V8
i have a 2002 ram 1500, I have disconnected the heater lines to the firewall and have flushed the heater core till it ran freely and clear water. But I only have heat coming out the passenger side air vents, cool air comes out the drivers side?Also I have a hint of ant freeze smell outside the truck after it runs for a while but no one can find a leak?
Do you
have the same problem?
Monday, November 30th, 2009 AT 11:05 AM
  • EXPERT
The interior problem is most likely a result of a bad vacuum hose. The vents are actuated by engine vacuum. Chances are one of the vacuum hoses under the dash is either broken, disconnected, or cracked. As a result, the vent isn't allowing heat to make it to its destination.
Check for leaks. With the engine running, you may hear a hissing sound.
Let me know what you find.
Friday, December 4th, 2009 AT 10:52 AM
Recommended Guides
