2001 Dodge Ram will not blow out cold air warm air only
AMCKEY
  • 2001 DODGE RAM
  • 6 CYL
  • 120,000 MILES
My 2001 dodge ram 1500 only blows out warm air when the air conditioning is on. Air conditioning system vaccumed down, refilled with 2.8 pounds of refrigerant, compressor clutch cycling continuiously, system leak test good, no leaks, lines and accumalator gets very cold, replaced heater and air conditioning controls assembly switch.
Do you
have the same problem?
Thursday, August 12th, 2010 AT 12:35 AM
Hi amckey, Welcome to 2carpros and TY for the donation
Probable causes could be the blend air door on the HVAC unit may be stuck in the heat position blocking off the air flow so no air goes through the evaporator, also the cabin pollen filter that is blocking off airflow, another possibility would be a fault in the automatic climate control system such as AC temperature sensor or the HVAC control module.
Thursday, August 12th, 2010 AT 1:14 AM
Recommended Guides
