1999 Dodge Ram starting
JOZZY
  • 1999 DODGE RAM
Engine Performance problem
1999 Dodge Ram V8 Four Wheel Drive Automatic
my truck will start and then stall on some days and other days it will stay running just changed the idle control censer and the problem is still there looking for some help
Do you
have the same problem?
Monday, February 22nd, 2010 AT 12:25 PM
CARADIODOC
  • EXPERT
If the battery was recently disconnected or run dead, the engine computer must relearn minimum throttle before it will know when it must be in charge of idle speed. To meet the conditions that will cause this to take place, drive at highway speed with the engine warmed up, then coast for at least seven seconds without touching the brake or gas pedals.
Caradiodoc
Friday, February 26th, 2010 AT 5:00 PM
Recommended Guides
