1999 Dodge Ram
MIDGETT
  • 1999 DODGE RAM
  • 6 CYL
  • 4WD
  • 230,000 MILES
My Dodge Ram 2500 Cummins diesel truck transmission shifts erratically through the forward gears. Often it remains stuck in 1st, 2nd and/or 3rd gear for a long period of time and well past the engine rpm that it should have upshifted. The transmission does not slip. I've changed the fluid and filter with no improvement. I consider myself to be a half decent mechanic but I am stuck. Please help.
Do you
have the same problem?
Wednesday, July 1st, 2009 AT 6:21 PM
DOCFIXIT
  • EXPERT
Hi
Most common problem with Dodge trans. The governor and/or solenoid is faulty. No code is set but a pressure test will show if governor pressure low.
Governor on valve body
Hope this helps
Thanks for donate
Jasper has reworked trans to over come dodges weakness.
Thursday, July 2nd, 2009 AT 9:21 AM
MIDGETT
Thanks for the reply.
Where is the solenoid located?
Sunday, July 5th, 2009 AT 12:24 PM
DOCFIXIT
  • EXPERT
Governor and solenoid come as one unit. It is on valve body. Sorry I did not make that clear
Sunday, July 5th, 2009 AT 12:51 PM
Recommended Guides
