Rollover fuel shutoff switch
BTSTOM
  • 2000 DODGE RAM
  • 6 CYL
  • MANUAL
  • 160,000 MILES
I have a 2000 Dodge Ram diesel that quit running abruptly after hitting a very bad bump. Is there a rollover fuel pump/ engine shutoff switch on this truck like cars have? If so, where is the reset for it? I don't want to change the injection pump and find out I have a minor electrical problem. We have checked everything else, but can't find any reference to a rollover shut off like most cars have. Thanks for your assistance.
Sunday, September 13th, 2009 AT 12:21 PM
DOCFIXIT
  • 18,828 POSTS
Hi
No rollover switch. Do you have fuel pressure? Have checked ASD relay and pump relay?
Let me know
Thanks for donate
Sunday, September 13th, 2009 AT 2:24 PM
BTSTOM
Thanks for the quick response!
I have fuel pressure and plenty of fuel coming up to the injector pump, no pressure after the pump, tried to bleed system, no fuel at injector lines.
I have checked the fuel pump relay and the ASD relay and they both are working properly.
Sunday, September 13th, 2009 AT 4:01 PM
DOCFIXIT
  • 18,828 POSTS
Try bleeding low pressure side first at banjo fitting
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_125.jpg
Then open injector 3-4-5 bleed
https://www.2carpros.com/forum/automotive_pictures/198357_Grafic_3_36.jpg
Let me know
Monday, September 14th, 2009 AT 9:47 AM
BTSTOM
I bled the low pressure side thru the banjo fitting while cranking the engine. Got some air out. Afterwards, still no fuel at the injectors.
Thursday, September 24th, 2009 AT 2:53 AM
AJACOBS1945
  • 1997 DODGE RAM
  • V8
  • 4WD
  • 14,200 MILES
Where is the fuel pump cut off switch?
Tuesday, October 1st, 2019 AT 6:43 PM (Merged)
JDL
  • 16,098 POSTS
Hi, there isn't one. With engine cranking, I'd check voltage and ground at fuel pump connector. Dark green wire with black tracer is voltage, black is ground. Next,I'd check circuits at the fuel pump relay.
https://www.2carpros.com/forum/automotive_pictures/170934_ram_fuel_pump_1.jpg
The picture is the fuel pump module, not the relay.
CHUNKY73
  • 1996 DODGE RAM
Where is the fuel pump reset switch?
There's no reset switch for this vehicle its not like Ford products that has the inertia fuel cut off switch-
