1997 Dodge Ram gears does not go into place like they are s
MAEROSIA
  • 1997 DODGE RAM
1997 Dodge Ram V8 Two Wheel Drive Automatic
my husband just brought this truck and now I found out thet the gears does not go into gear as it suppose to it's not bad yet but I dont want it to get bad, he also has some noise with it. Can you possiblely tell me what may be up with this truck?
Do you
have the same problem?
Friday, July 17th, 2009 AT 12:26 PM
  • EXPERT
Hi there,
thank you for the donation,
You will have to check the transmission oil check the level is correct and it is a bright red colour, if its dirty and smelly, this is not a good sign, I would get it tested by a transmission specialist as it will require a number of hands on tests to determine what is your problem, a transmission specialist will have all the equipment require to do this inspection & report for you, start here.
Mark (mhpautos)
Saturday, July 18th, 2009 AT 4:58 AM
